AStinker-
Mar 13, 2014Explorer
Portable Solar Panel Question
I want to put together a portable solar system to experiment & learn with this summer to decide if I really want solar. My goal is to get as many watts as possible but keep the weight per panel under 20 lbs. I was looking at Product A and B listed below and was getting ready to order Product B when I decided to look for some other lower priced 100W panels. What I found was most other 100W panels weighed more( Example: Product C ) than Product B. I am ignoring the cost per watt delivered to my house in this scenario but left it in because I am guessing someone will ask. I am also ignoring the fact that portables can walk away, won’t be usable while traveling, probably won’t get used because I’m lazy and in general are a PITA.
So my questions for you guys is:
1) How much does the weight of a solar panel affect the quality?
2) Is there other factors in the specs of the 3 panels listed below that should be a bigger factor in influencing my decision?
Product A
Manufacturer: W Solar
Max Power: 75W
Open Circuit Voltage (Voc): 23.36V
Short Circuit Current (Isc): 4.17
Maximum Power Voltage (Vmp): 18.0V
Maximum Power Current (Imp): 4.28A
Weight: 15 pounds
Dimensions (inches): 38.61 x 23.79 x 1.17
Cu Inches: 1075
$1.40/watt
Product B
Renogy Solar Panel
Maximum Power at STC: 100 W
Open - Circuit Voltage (Voc): 22.5 V
Short- Circuit Current (Isc): 5.75 A
Optimum Operating Voltage (Vmp): 18.9V
Optimum Operating Current (Imp): 5.29 A
Weight: 16.5 lbs
Cu Inches: 1402
Dimensions: 47 x 21.3 x 1.4 in
$1.50/watt
Product C
Manufacturer: Solar Cynergy
Max Power: 100W
Open Circuit Voltage (Voc): 21.0V
Short Circuit Current (Isc): 6.30A
Maximum Power Voltage (Vmp): 17.0V
Maximum Power Current (Imp): 5.80A
Weight: 25 pounds
Dimensions (inches): 44.00 x 26.50 x 1.25
Cu Inches: 1458
$1.31/watt
Product A
Max Power: 75W
Weight: 15 pounds
Cu Inches: 1075
$1.40/watt
Product B
Renogy Solar Panel
Weight: 16.5 lbs
Cu Inches: 1402
$1.50/watt
Product C
Max Power: 100W
Weight: 25 pounds
Cu Inches: 1458
$1.31/watt
This was Oct 25th, 2013.
