WFCO converters require a low resistance connection to the battery to work properly. Close to all RV installations do not provide a good enough connection, and the converter never ever enters bulk mode. The battery size also needs to be matched to the converter. If the 65 amp converter is paired with a single battery it will likely never enter bulk mode. If you don't often use a generator to charge the battery this is likely an insignificant detail. Not going into bulk mode greatly lengthens charge times and if you use a generator for charging this could turn into an important detail. As a quick check, run your battery down to 50% or less, apply shore power, and measure the voltage at the battery. If it's under about 13.75 volts the converter didn't go into bulk mode and likely never will. Because of this behavior a lot of RVers replace the WFCO converter with another brand, more often than not, Progressive Dynamics.
