Busdriverjoe's avatar
Busdriverjoe
Power Panel Location
2011 Dutchman Denali 289 RK Cannot locate power panel. Just lost heater and lites on refrig. Checked all cabinets, below seats, etc. NOT under refrig. HELP!
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Look for a flat black plastic panel.. Basement or outside compartments. Inside anywhere.. Alas I think there is a contest to hide things like this.
    Final option woudl be a device called a "Tick Tracer" this is a Radio transmitter with clip leads. you unplug from shore power. clip it to the water heater's power leads at the relay.
    Then using the receiver you swing it past the wire. You will hear a BEEP as the "Wand" points to the wire. Well follow the beep. when it ends. you are pointing at the power panel.
  • Old-Biscuit wrote:
    Main AC Panel and DC Dist Panel should be inside same cabinet with converter located in bottom section
    My converter is on the other side of the rig from the power panel.
  • Main AC Panel and DC Dist Panel should be inside same cabinet with converter located in bottom section
    Loss of furnace/lights to Fridge.....DC issue
    What is below oven?
  • I don't have your type of trailer but on my two previous trailers and the current one the power panels were located near the end of the power cord but inside the trailer behind a cabinet door. Your inverter or converter may also be at fault check to see if a breaker has tripped on the device. Once in awhile mine will trip.
    GFCI outlet may have tripped somewhere on the same circuit as the heater.
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
