RDMueller's avatar
RDMueller
PowerMax Boondocker + DROK Voltage booster = nice setup
Finally have all of this put together! Very much want to thank everyone here who helped me figure it all out and actually understand what I'm doing. I have to say, I'm very pleased with this combination and put it together at a reasonable cost.
The only pricy component was the Boondocker, but I felt it was worth it because it looks very durable and will work as a stand alone charger (without the DROK) for a quick bulk charge off the generator if needed while on a trip. 60A is pretty respectable and a good match for my 2 T105s. I'll even keep it with me when I'm camping with hookups because if the WFCO happenes to conk out some day, I have a backup means to provide 12VDC.
Then, when I'm at home and charging via commercial power, put the DROK and ammeter into the mix and charge at exactly the profile I want to. Equalization charge? No problem. Desulfate? No problem.
Still want to get some plugs to quickly add or remove the DROK and ammeter, but basically this works well as is right now. Since I'm not in a hurry at home, I'll just keep the charge rate low, then the wiring is adequate as is and the DROK doesn't even get warm. Put me down as totally sold on manual absorption charging!
Both from Amazon with free shipping:
DROK
FT08 Ammeter
