Travelin2
Feb 13, 2019Explorer
westend wrote:
The controller is shorting across the umbilical posts due to water inside the connector, most likely. I had my P2 exhibit similar codes when I was disconnected from trailer and a load of icy salt-snow mix around the truck's connector. A full dose of WD 40 cured everything. I followed that up with a spray dose of Caig Deoxit to remove any rust or oxidation.
X2
