path1's avatar
path1
Propane system question/regulator
Problems with propane regulator(s).
Bought RV 2 years old. (2013) When one bottle of propane is empty the indicator gauge does NOT flip to red, until both tanks are empty. Then flips to red.
Replaced regulator with the same brand and model (2015) that came with RV. Same as the OEM installs, a cheap China model. Same problem, when one tank empty's the indicator stays green until both propane bottles are empty.
Replaced regulator with different model (2016) that was pricey ($70.00) purchased at large propane distributor. Distributor said he has had only two bring backs with this regulator and says he goes thru many. Same problem...red indicator only shows when both tanks are empty.
Question...
I think my problem is somewhere else in propane system. But I have no idea what that would be. What would make a regulator (3 of them) only flip the red indicator when both tanks are empty?
And not flip indicator to red when one tank goes empty?
I think the odds of three regulators that are bad are slim.
And I don't know where to look to solve the problem.
Any help?
Thanks
