kendeena's avatar
kendeena
question for full timers re black tank
Hello Friends.
We have involuntarily become full timers... We moved into our motor home in January after discovering black mold in our house. I'm no rookie, we've put 70k miles on our pace arrow over the last 10 years with great joy. Long story short, we are parked right next to the septic tank so that I can dump directly into it. Anyway, I've been dealing with the black tank like I've always done, waiting for it to get full enough so that I get a good empty and treating with the normal stuff. In the last few months the odor has become unbearable. I'm talking eyes watering stomach convulsing beyond comprehension zombie afterbirth bad. We have about another 2 months to go before we can get back in the house. I'm thinking a solution of a bunch of baking soda, vinegar, and filling the tank up about half full, then taking a Robin Williams type drive and a purgative evacuation might be the solution, but frankly I'd rather not move the beast. Any advice on a plan of action would be most appreciated.
Thanks for the hard earned wisdom.
Kj
  • If you don't have an internal tank sprayer... and you set still for a long periord of time (Months)... you need something to spray the interior of the black tank. Just waiting until the black tank is full to dump and thinking the vent/suction will be enough to pull the solids from the bottom of the tank, will get you a smelly tank with sludge at the bottom.
    We've tried the gadgets that have a place to screw a garden hose to them ...and put water in the black tank from the sewer connection outside... and they don't do enough. We don't have a straight shot into the tank so it loses the spray factor. It's just filling the tank through the black tank valve. It's not squirting or spraying.
    The best gadget we've found is a 3 foot long hose that is flexible enough to bend around a corner and has holes in it to spray water. Attach that to a garden hose (that you don't use for fresh water), put it down the toilet and make sure it gets into the black tank. You might have to bend it with your hands first, before you put it down the toilet, to get it to bend enough. (You should be able to see the connection where you've screwed it to the hose - don't push it into the tank so far that you couldn't get it if it came off the hose.)
    Then turn the water on and let it spray. It works well to just let the black tank valve be open for a bit. Having a clear plastic piece between the valve and the sewer hose will let you see what's going through it. After a bit, close the black tank valve and let it continue to spray as it fills the black tank. (Having a person inside (with a flashlight to look down the pipe) and another outside works the best... takes the worries out of something going wrong. Use phones or walkie talkies to communicate back and forth.
    When the tank is past 1/2 full, pull the black valve and let it drain while the sprayer continues to spray.
    We set still for months at a time. The summer months are the smelly ones. Flushing the tanks more often helps a lot.
    One more thing - we don't put toilet paper or any paper products in the tank. It goes into a plastic bag and out with the trash. So far, we have not had a problem we couldn't solve "from above".
  • Bobbo's avatar
    Bobbo
    Explorer III
    In addition to making sure the vent from the roof is not plugged, you may need to replace the AAV (Air Admittance Valve) under the cabinet by the sink. It is a simple screw off/screw on replacement.
  • Both are good solutions . Thank you . I'll give it a whirl and report back.
    Kj
  • I just re-read your post and didn't see anything in it about flushing the black tank after dumping. Get a clear adapter to put on the end of your sewer pipe. Dump the black tank normally. Then close the valve and fill the tank about 1/2 full. Dump again and see how much stuff was still in there. Repeat this process until, or just stick a garden hose down the toilet, until you see clear water running out.
  • I don't know that there is much that can be done...doesn't sound like your dumping from full...
    You could get a plumbing snake and stick it down in th tank and thrash it about for a while....remember to have a bucket to coil it into as you pull it out...
    We had a smell problem on long road trip a few years ago, the baby wipes were not dumping out and accumulated in the tank...I took a garden house and put one of those little brass high pressure novels on it, hooked to my stick house hot water and pushed it down into the tank and turned it on full....
    For the time being, a full bottle of pine sol will keep the zombie rot at bay
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Aug 01, 2025
