Rbertalotto
Aug 27, 2013Explorer
Reading AMPS from a solar panel
I have a 12v - 120W solar panel on my TC. This is controlled by a Morningstar Sunsaver 20 into a single group 27 wet cell battery.
I have a Trimetric 2025RV battery monitor installed.
As far as I can see, the Trimetric does not show the solar panel voltage or amps, it only shows battery readings.
I bought a simple Volt / Amp panel mount meter with a shunt.
DROK 0-100V/50A Digital DC Panel Volt Amps Tester Meter VA 2in1 Red LED Display+Shunt
It included three different wiring scenarios:
The question is...Is there any way to use this meter to report Volts and Amp coming frm the solar panel?
Thanks!
Thanks!
