- KountryguyExplorerI do not use them often, but the two in the rear act as back-up lights.
- wa8yxmExplorer IIIDO NOT. Those scare lights are an annoyance.
However if you must good advise up thread. - buckyExplorer IIA standard 1156 may melt the lens.
- Who are you trying to scare?? Your neighbors?? ha, ha... :)
- down_homeExplorer IITook out the old and replaced it with LED 1156 equivalent I believe. Many variations some with a few leds some with many more. I paid too much an an RV parts place about 11.00, I think. On line many a lot cheaper. I installed the longest one that would fit. They will fit all the bay or luggage compartment lights too and 12 volt lights inside but might be a bit intense. On line they list the brightness in degrees kelvin, I think.
- bob213Explorer1156 is brighter. Here's the description: the 1156 replaces the 1141, has the same physical characteristics, is brighter (26.9W vs 18.4) and uses more current (2.1A vs 1.44).
Try superbrightleds.com
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
