GordonThree
Aug 15, 2017Explorer
pyro383 wrote:
I am needing to replace the male end of the shore power cord for my rv as the previous one had melted a bit at one of the connectors. My dilemma is to replace the male end with a replacement adapter made by Camco (not weather tight) of which I would add silicone around the openings or to replace the full length cord. Cost is $13 vs $45.
Don't try to make it weather tight, all that's going to do is trap moisture inside and speed up corrosion.
If you want to protect the studs / screws inside the housing, paint them with battery terminal protection paint, or apply vaseline or another grease after making the connections.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
