MEXICOWANDERER
Aug 15, 2017Explorer
I solder appropriate spade (fork) terminals onto stranded wire ends then when assembling tighten the snot out of plug/receptacle clamp screws. Gobbing electrolytic silicone grease onto each finished termination makes this method of assembly better than any other - especially if a good plug or socket like Chris Bryant recommended is used. The object is to stop heating and cooling cycles which anneal the copper wire strands beyond salvation.
I arrived at this conclusion decades ago after fighting my own makeup plugs which were necessary after pre-made factory molded plugs caught fire.
I would LOVE to see a failure in the assembly of how I assemble plugs. Being both lazy and cheap I sought the permanent fix. I found it.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
