dougrainer
Jul 08, 2018Nomad
Check the 12 volt wiring at the HYd pump motor and make sure the cables are tight. Check the wiring from the Pump motor to its source both neg and Pos. Also, have someone operated the slides and take a 12 volt measurement AT the hyd motor and see if the voltage drops below 12 volts when running. Some Hyd and electric slides use a auto reset 12 volt breaker. If bad or loose connection they will trip and reset within a few seconds. If this has happened since new, they may have installed the wrong size breaker for the slide system. Doug
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
