dbischops
Jul 09, 2018Explorer
Don't see anything that looks like a breaker/fuse between the battery and the pump.
The positive cable runs to some studs before going to the battery, but this is where other wires are split off from as well (landing gear etc). The wires are just bolted together. The negative wire goes up into the trailer.
Within the trailer there is an automotive 20A fuse (not self resetting) listed as Slide, although this is likely for the outlets/lights but this fuse is fine.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
