MrWizard
Jun 08, 2017Moderator
take a good look inside picture #2
i don't about you guys
but to me that looks like the flange was glued to pipe with black ABS cement
IF so its not coming out of there with out cutting things apart
might want to get a plumber to give an opinion
a grinder or a saw will cut
BUT how do you get the new pieces back together with out leaks
won't be able to slip a new flange stem over the existing flange stem still glued to the outside or inside of the pipe
will have to 'BUTT' them together and use and inside nipple to glue everything together (if you cut it apart)
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
