eHoefler
Jun 09, 2017Explorer II
You can replace the floor without removing the flange, done it many times, including in RV's. It is most likely solvent welded in, and the only way to remove it is to cut it. If the tank is tight against the floor, yu may not beable to glue it back together without replacing everything from flange to tank flange.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
