dougrainer
Jun 09, 2017Nomad
There are only 2 ways the 3 inch DOWN pipe is connected to the Black tank.
1. Rubber Grommet and the 3 inch pipe slips into that Grommet
2. The 3 inch down pipe is threaded and you have to use a long pry bar between the 2 closet bolts '/, in the flange to break the pipe loose.
I have NEVER seen one glued from the factory. Gray tank inlets yes, but not black toilet down pipes. Doug
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
