401nailhead
Apr 09, 2015Explorer
Thanks everyone for the great answers, examples, and especially the safety info. Here are the updates, from following the advice:
took the microwave out of its cabinet, and plugged into outside power source. Has the same quirks, and I will now run it by a local repair shop that has very affordable estimates/diagnosis. Will have fixed or replace if needed. I will still test the outlet as well, just as a precaution.
Will check the 120 V refrigerator heat element. Have not had time yet, but watched a couple videos, and will check the manual over the weekend.
Will look for a replacement switch for the water heater.
Even though the replacement vent/fan is on order, I figured I would look into why the current fan was not operating, in case it gives me insight into the wiring condition. Now I see the answers, the fuse question on the fan was trivial, but I wasn't sure when I asked.
I'll get the sensors/alarms replaced as a priority. I will probably go with basic battery power models immediately, then make a decision on replacing flush mounted built-in models.
As soon as I have clear, dry weekend day free, I will launch a major campaign to check all caulking and sealing, and re-seal as needed. This will be a priority. The Dicor lap joint compound is coming in the mail soon.
Thanks again to everyone; I will probably look back on my questions in a year and think how simple and basic they were, but everyone has to start somewhere, and this is my initial starting point.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
