Pops_R's avatar
Pops_R
Shore Power
When connected to shore power it should run everything on the MH correct? In my case (and we are in extreme cold weather in Colorado Springs at present) the furnace will only work when connected to the house dual 6 volt batteries that came with the new MH. If I use the disconnect switch inside the MH to just use the shore power then the furnace will not work or any interior lights yet the TV, Microwave, and electrical plus do have power.
The house batteries just continually loose power and will only last for about 2-3 hours and I need to start the engine to bring them back up and maintain the heat using the furnace.
If left alone the dual 6 volt house batteries just drain down till the Xantrex PRO Inverter gives the low voltage error code, so to avoid that requires the MH engine to be turned on every hour or two for a few minutes to bring the batteries back up to keep the MH warm and its underbelly heated for the holding tanks.
During the day time I can shut off the furnace and only turn it on as needed and use the electric fireplace heater to maintain a comfort zone inside the MH
I have to assume those original house batteries are just weak damaged and unable to hold the charge but also have to wonder about the 1800 Watt inverter that is said to be able to run everything in the MH and keep the house batteries charged up.
Any insight from anyone out there on this situation?
2015 Thor Challenger
