ruger77 wrote:
enblethen wrote:
Verify the diverter valve in the shower and outside shower are closed.
Have you connected it back to city water to see if it operates correctly? It is a good idea to the use city water connection to fill system including the water heater.
going to have to check for valves tommorrow! The state park I'm at has no water hookup s. I let the pump run for an hour with no luck
found it this morning I trace the water lines and on the supply line from the tank was a valve near the pump that was set to a 3ft hose with a cap on it. Turned it in line with the supply line to sink and bam WATER! Dealer must of left it like that after sanitizing it!!! Thanks for everyone's input!
