- HandbasketExplorerDoubt it'd be an issue here, but some larger Navy diesels back in the day (50's-70's, anyway) had spring-loaded flaps on the block sides. These were one each side per cylinder. They could be removed to improve access during rebuilds, but their real purpose (AIUI) was to vent crankcase explosions caused by excess fueling. The intent was to save the engine block.
I saw one brief training film... quite impressive to see foot-long tongues of fire shoot out of the side of the block. Nothing was said about what would have happened to the engineroom crew, of course.
Jim, "The Navy! It's not just an adventure, it's a dang dirty, greasy job!" - westendExplorerAgain, this would be a good time to drain and replace oil. The last engine I saw that had a fuel->oil problem like yours shot a piston/rod through the block. Oil is cheap compared to engine replacement.
- faucet1ExplorerWell let's hope I find the source/problem before I lose an engine. Thanks for all of your comments.
- MEXICOWANDERERExplorerSort of like wondering why the smoke detector didn't sound when flames are leaping up into the sky.
There will be a noticeable loss of oil pressure. This is a death knell signal.
Crankcase oil DOES NOT SMELL LIKE DIESEL FUEL.
If you smell diesel fuel on the dipstick, it's time for the pickup to go to the diesel hospital. - faucet1ExplorerSo, when you get dilution, am I to understand that there is no smoke to be seen coming out the exhaust? One would think as the fuel leaks in, this extra fuel would cause some smoke.
- MEXICOWANDERERExplorerAny dilution of lube oil with diesel fuel is dangerous and WILL lead to total engine destruction.
Diesel fuel and lube oil mix wonderfully, like vinegar and water. - faucet1ExplorerIn response to Westend, I don't smell diesel in the oil, but there probably is not enough to smell as yet. Just changed the oil in January, and have driven less than 2,000 miles. The oil level is only about 1 to 1.5 quarts above the level right after I changed it(I generally check oil before going on an outing). So, if something has changed/happened, it did so since the 1st of May.
- carringbExplorerYup. It mixes. If your motor start "making" motor oil, time to dig deeper. It can tolerate some dilution, but not much. On out '08 Cummins 6.7L trucks, we had to switch to 4,000 mile oil changes due to oil dilution. On our case, the excess fuel was from the trucks being frequently in Regen mode. Cummins uses the regular injectors to dump extra fuel into the cylinders so it burns off in the DPF.
- faucet1ExplorerIf there is a leak into the crankcase it may/could be bad or deteriorating seals in the injector pump(as I understand). When an engine is shut down the pressure at the pump is quite high, and if an injector were open at the point of shut down I suppose the fuel pressure might push the remaining fuel in the line into the cylinder and down past the rings. Any of you diesel mech ever seen this happen? I did start the engine and didn't see any smoke from the exhaust. This is a 2002 engine and is electronic ignition. Will an injector remain open with the ignition switch off?
- HandbasketExplorerI don't know about newer emission-controlled diesels, but from 4 years of USN experience with diesels up to 2031 CID 'back when', I'd expect a stuck-open injector to result in lots of black smoke, especially at full throttle / under load.
Jim, "Mo' coffee!"
Having RV issues? Connect with others who have been in your shoes.24,318 PostsLatest Activity: Sep 14, 2025
