5Cent's avatar
5Cent
Stand alone battery charger recommendations
Situation: Annual atv, archery, shooting get together.
- 2015 Keystone Hideout 28BHS, electric slide, electric awning, electric jack. RV will be plugged into high-idle Duramax when setting up and tearing down.
- Currently running stock, dealer installed Crown MAR-600, 12V battery. I expect around 55-60 amp/hrs. is spec.
- Going to be off grid next weekend, Thursday-Sunday.
- Fuses will be removed for radio unless used, and hardwired co2 detector out entire time. May run fridge, may not on LPG. Only running waterpump when needed. Long time-period draws the unit will be plugged into the generator.
- Champion 4000/3500 generator will tag alone and will already be running for 5-8hrs per day for other event reasons.
- OEM WFCO Model WF-8955PEC (13.6vdc & 55A output - rating includes charging & load)
I will eventually upgrade to dual 6v batteries, but I need a charger anyways, so figured best to invest there first. Looking for recommendations for best charger under $150, preferably $100.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
