pcm1959's avatar
pcm1959
Explorer II
Aug 09, 2014
Swiching for a dedicated Refrigerator inverter
I need some help form those experienced electricians out there with a wiring question.
I am in the process of installing a residential refrigerator in my fifth wheel RV. I'm wrapping it up and ready to install the new refrigerator.
I have run a dedicated 110 line to the refrigerator from the inverter. There is a single 110 outlet behind the refrigerator that is part of the RV wiring that is on a branch circuit and breaker. I would like to be able to use the outlet that is currently in place to plug the refrigerator into. My desire is to be able to install a switch on the wall beside the refrigerator to manually switch between the shore power and the inverter power. I am not sure if this can be done. I was told to buy a double throw double pole switch to achieve this but I'm very confused as how to wire it.
I do not have an a/c powered inverter nor does it have an auto switch over. I would just like to switch between the two power sources using the existing single plug. I do not know if I have the correct switch but Have been told I do. I just don't know who to wire it. Please advise. Thanks, Phillip
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
