DD716TED's avatar
DD716TED
tank level sensor wires..repair
This past week while on the road, I noticed that one of the black tank sensor wires (yellow) had been severed by the stabilization jack. a short piece of the wire is still attached to the tanks sensor button.. can I just solder the wire back together then heat shrink the joint without impacting the resiatance of the wire or is there a better way to make the repair like using the a telephone wire plastic press connector?
  • enblethen wrote:
    Solder and heat shrink would be the best.
    Ditto but it's just a low voltage wire, whatever you have handy to make a good splice would work.
  • DrewE's avatar
    DrewE
    Explorer III
    Any of them should work just fine. The resistances of the tank contents and the resistor pack are in the range of kilo-Ohms; all you need is more or less continuity. Solder and heat shrink is just fine; a weatherproof telephone connector would also be just fine if it's suitable for the type of wire (I think some are designed for solid wire only and not recommended for stranded wire).
    It would seem to me to be a good idea to tape or otherwise restrain the wire and its compatriots so it doesn't run afoul of the leveling jack again.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
