GordonThree's avatar
GordonThree
thermostat failure on electric heaters
Four electric fan type heaters, now with dead / unreliable thermostats. All different brands and models.
Do all the thermostats come from a single factory in China?
Is RV travel damaging the thermostats?
I plan to replace the failed thermo with a temperature fuse instead, and use an external digital thermo, but ugh that's work.
  • Hi Mex,
    Tell us more? Is this similar to adjusting an anticipator?
    MEXICOWANDERER wrote:
    I opt for the mechanical units where I can slip the cover off an tweak the Delta T to my satisfaction.
  • I opt for the mechanical units where I can slip the cover off an tweak the Delta T to my satisfaction. For heating a 7 degree Delta T (temp drops 7 degrees then heater restarts) seems to like me. For my Fantastic Fan Endless Breeze a mechanical A/C thermostat works great usually shuts down around 75F.
    Power outage. Summer. 0230 Power blinks. A/C shuts down. When it comes back I have a 2-minute delay timer connected to a Deltrol relay. Blinkity blink blink blink, the A/C stays off. Mechanical controls means auto re-start after 2 minutes. Saves component parts in the A/C
    If those junky OEM thermostats don't come from the same factory, they all come from the same business park boulevard and the factory leaders all take lunch together.I've taken them apart and they are utter garbage. The digital jobs are prone to doing a Lucas Ltd at the drop of a hat as well.
    PM me your mail packages to Gordon Three and I'll envelope you a fixed 160F 15-amp cutout rated for 35,000 cycles at 30 amps. Just futz around till you have it located where it accidentally guesses your preferred temp. Made in Germany by my relatives. Deutschland Uber Alles!
  • You can still get bi-metallic thermostats that are rated to switch line voltage (240 actually). Why not try to adapt one of those?
    EDIT:
    Quick look finds Honeywell T498. rated 22A@240V. Ought to be able to handle 1500W heater no problem. Can get creative with various mounting options.
    Or this:
    Manufacturer Selco
    Mfr Part # OA-70
    Description Thermostat; 1/2 in Disc; Auto-Reset; Open on Rise; Open at 70 F; Close at 50 F
    15A@250V
  • Hi GordonThree,
    I dislike the digital thermo's because if the 120 volt power fails, they default to "off".
    The heater's I've ripped apart came with a temperature fuse in series with the thermostat. I see no need for two.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 19, 2025
