dougrainer
Aug 30, 2016Nomad
There is no inner and outer tank. Flush the black tank a few times and then start to fill the black tank thru the toilet. Watch the toilet down pipe and stop when you see the water start coming up the down neck. Then see if you have leaks. If no leaks, all os good and tight. IF it leaks, then get it fixed. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
