Matt_Colie wrote:
CJM,
Without knowing the specifics of the TV and TT, I fear you are headed for a disappointment. Even if the the TT house bank is on the tongue, we are talking a long run of cable. Remember, to make this work right, you will not be able to count on the frame of anything as a conductor.
With the entire life of a Lead/Acid battery between 12.0 and 12.6, and peak charging limited to 14.4 (or .6), there is no room for voltage drop. So a huge alternator will be a lost cause even if you run welding cable from the alternator to the house bank.
A Renogy charger will be a big help, but you are still stuck with the recharge time being limited by the battery chemistry. Even AGMs, though will charge faster, still have limits. They just get to 90% a lot faster if you can feed them juice.
You do not say what the installed converter is in the TT, but if it is not a modern 3 or 4 stage unit like Progressive Dynamics or Iota (there are others now) that does a boost, bulk and float, I suggest you replace it first.
Then, go an buy an inexpensive little genset. Try not to buy a "Contractor" unit because they are designed to cover up the noise of hammers and Skilsaws. There are more than a few on the market. Then, you will also have the portable for other uses. (You will find some.)
I know of a guy that boondocks with a long cab TV and a TT that ties his generator down in the bed and runs it when underway. He just runs the shore power cable to it. (With some duck tape for control.)
This will all be more simple and reliable than the alternatives, you will just have to put up with some noise some times.
Thanks for all the insight first.
Details I hadn't mentioned:
1. I replaced the OEM WFCO converter last year after I installed both GC2 batteries. It's now a 55amp Powermax 3 stage converter. Seems to be better at keeping the bank topped off when on shore power.
2. I'm preparing for an Alaska trip with the family next summer and am looking for a viable (and practical) solution to keep the batteries near 80-90% SOC when we arrive at each destination. The plan is to boon dock at least 3 out of 4 days during the 8 week trip.
3. I have a budget of around $2,000 for 'power' upgrades (per the wife). I would love to have a couple of LiFEP04 but pricing is just a bit out of touch for a non-fulltime expedition.
4. The trailer is a 35ft ultra lightweight model with a non-walkable roof. I'm leaning against a solar array as it would a daunting task to mount and maintain them on the 1/4" thick roof decking. I would consider a portable unit but how influential will it be under the northern Canadian and Alaskan skies? What's the cost benefit?
5. We will be bringing an inverter generator (Westinghouse 4500w/3800w) with us. I don't know how "generator friendly" the Alcan hwy is (or the waterfront campgrounds throughout Alaska). I would rather use it as seldom as possible.
6. I did install a pure sine power inverter (1500/3000 watt) in the passthrough storage bay. Don't know if it's just the brand, but it fails to run the 900 watt microwave. A new inverter may be required as the wife is insistent on that appliance for light meals for the kids. I've been reading that 6 volt golf cart batteries in series don't perform nice with large amp draws verses a similar amp hour 12 volt deep cycle bank wired in parallel. I'm also under the impression that flooded lead acid batteries have different discharging characteristics than AGM batteries. I'm considering an AGM upgrade even though my wet cell GC2s are only a year old.
I'm trying to determine what electrical upgrades are most beneficial without breaking the bank. The DC to DC power charger is top on my list. I'm questioning the long run of cable from the front of the TV to the trailer's passthrough storage. Based on what I'm hearing, I'm going to hold off on the alternator upgrade. The TV's little 600 CCA battery could be changed out for a higher capacity battery. An AGM upgrade to the GC2s is a possibility too. Don't know how I can increase amp hours unless I move to Lithium. The task of defining which components to upgrade (or add) is becoming a challenge. Even though winter will keep the coach idle, June is approaching fast and I'll need solutions before the weather breaks.
