Chinolbz
Oct 29, 2019Explorer
Transfer Switch
I think my TS is dead. No 110v getting through. Any way to jump around it to keep me going while dry camping on a gen? Thanks
time2roll wrote:X2ADAD437 wrote:I thought standard TS was connected to the cord as default. If you start the generator there is often a 20 second delay to switch.
if transfer switch goes bad it should default to generator therefore you should have power when gen. is running. been there done that.
And when things fail they don't necessarily reset to some position. Could be a loose or burnt connection for all we know.
Chinolbz wrote:First step is to measure the gen AC at the ATS to make sure the gen is OK.
Bill.Satellite wrote:
There are several devices made to connect larger wires together. The TS switch will have wires coming in from Generator and Shore and a 3rd set of wires that goes out to the coach. Just connect the incoming shore to the outgoing wires (with the coach unplugged!!!!!) and you are back in business.
