Ski_Pro_3's avatar
Ski_Pro_3
Truck battery eval
Hi guys!
I figured the folks here could explain to me what's going on with the batteries under the hood of my truck.
I have a 2006 Dodge Ram diesel 4x4 short bed truck. It has 70,000 miles on it and mostly used to haul my camper in it's bed. The camper has 200+ watts of solar panels controlled with a Morningstar Pro Star PS-30 PWM controller. There's a Blue Sea battery isolator so that my truck's batteries are charged after my camper's batteries reach full charge. It also allows my truck's alternator to charge my camper's batteries.
So, with all that said, my truck's batteries are currently 4 years old and they measure 12.4 volts after sitting overnight. Voltage during driving or solar charging is 14.4 volts. Right after shutting off, with the camper off the truck, the batteries are around 13.6 to 13.8 volts. Over night, they drop to 12.4 and stay there for days.
Specific gravity of all the cells, this truck has two Group 65 FLA batteries, is between 1.25 and 1.26.
I've taken the batteries out and placed on a bench with a voltage controlled power supply. Current draw drops to zero at 14.4 volts, so I can't boost the specific gravity unless I put a higher voltage in. If I put 15.2 volts into the battery I can get a current draw of 4 or 5 amps. Not sure that's what is good though for the battery, just info for you experts.
Anyways, battery resting voltage is 12.4 volts, specific gravity of electrolyte is 1.26 across the cells.
I have a load bank, 100amps. Hooked up, it states green/good as I throw the switch and hold it. I only hold it for 15 or 20 seconds, but the needle stays in the green zone.
I suspect my battery is starting to sulfate and these readings indicate it's starting to just get old and wear out.
Any thoughts?
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 21, 2026
