Bionic_Man
Dec 02, 2014Explorer
RoyB wrote:
I suspect all you will get from the EF2000is is 13.3AMPs just like the Honda EU2000is.
Two of these connected together will only give you [email protected] AMPS.![]()
The MAX you can pull from the two 120VAC RECEPTACLES on the front panel is 20AMPs and this has been dropped down to 13.3AMPS I suspect..
Photos from GOOGLE SEARCH
Everything you read abut the Yamaha Generator says it is very close to the Honda EU2000is model in performance.
Roy Ken
This is what I have. I know on my 5er, it is adequate to run my converter, AC and electric hot water heater.
I also use it on my houseboat, where it will run the converter and a residential AC unit.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
