audiodane's avatar
audiodane
Using Dryer's NEMA 14-30 outlet for RV shore power
Hey folks,
UPDATE:
Skip all the banter and jump to the CURRENT PLAN using this link!
Original Post:
I've been reading lots of posts about using dryer hookups for RV shore power at home and lots of them are outdated (using the older NEMA 10-30 outlets). This question is about the newer NEMA 14-30 hookups.
(Edited to add this DISCLAIMER: For the sake of clarity, I am a degreed electrical engineer with ~20yrs experience and have worked around electricity my entire life. I have done plenty of wiring jobs at my own house and at the houses of friends and family. I understand electricity and the risks involved significantly well. I do plenty of electrical work, but do draw the line at installation of a new subpanel or main service entrance. :) I believe this thread is entirely useful for others who may wish to install a NEMA 14-50 outlet in their garage (whether for their RV or their Tesla). But, if you are not qualified to work on electrical systems, PLEASE do not take this thread as a suggestion that such a job is easy and without significant risk. I will not, nor will any other contributor to this thread, be responsible for anything you do as a result of this thread.)
For reference..
OLD style:
Link: Wikipedia NEMA 10 Style
Example:
NEW style:
Link: Wikipedia NEMA 14 Style
Example:
My house (build circa 2007) has the newer style NEMA 14-30 connector. When I put a multi-meter on it, it measures like this:
That seems to me equivalent to the necessary 50A hookup on an RV (albeit with only 30A's "actual"):
It also seems to me that I could use a 2-phase (DPDT) 30A switch to switch between my dryer outlet (inside) and a RV outlet (garage), using a switch such as the Leviton 1288 to switch power between the dryer and the garage outlets.
Leviton 1288:
However, I read over and over about people frying their RV trying to hook up shore power various ways from their house. SO I wanted to try and clarify what I think would work and get feedback.
It seems to me that I can use my dryer dual-30A hookup to power a 50A RV hookup with the stipulation that it will be limited to 30A per leg at the breaker box.
To be clear, our goals would be:
  • Park the RV in front of the house before/after trip for loading/unloading
  • Have Lights, A/C, and fridge running while loading/unloading
  • *NOT* planning on daily living use (microwave, etc)
It would seem to me that this circuit would be able to do the job.
My plan currently is:
  • Turn off dryer circuit breaker (safety first!)
  • Disconnect existing circuit from dryer outlet
  • Connect circuit from breaker to a DPDT switch such as the Leviton 1288 (linked above)
  • Connect one set of switch outputs to Dryer outlet
  • Connect second set of switch outputs to Garage RV outlet
Lastly, I want to again point out that this scenario would only supply 30A to each 120V leg even though we would be using a 14-50 style 50A RV hookup plug. This limitation comes from the breaker box itself. I cannot replace the breaker with a 50A because it would involve pulling new 50A wiring, and might violate dryer safety.
So, ..... thoughts?
cheers,
..dane
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
