NRALIFR's avatar
NRALIFR
Valence U1-12RT Lithium Battery
Anybody have any direct experience with these?
I was recently given two Valence U-Charge U1-12RT 40AH battery modules that were salvaged out of some hospital med carts. I’m not sure how old they are because I can’t make sense of the serial number tag.
These are (were?) marketed as “drop in replacement” for lead acid batteries, and each one has its own built-in BMS, and a pair of communication cables so they can talk to each other over an RS-485 interface.
The charging specs suggest that I could use my camper battery charger or my Redarc DC-DC charger on them, as both top out at 14.6. I’m not really concerned about the float voltage because I’d probably not have them connected to a charger all the time. I’ve only had time to play with them a short while, but they charged up till my Vector charger said they were “Full”, then held 13.3 for several days.
I have them paralleled right now, and I’m running them down with a small MSW inverter and a 150 watt heater. The user guide talks more about connecting them in series than parallel, and I’m not sure the communication cables even need to be connected when they are paralleled. According to the documentation, there is a Battery Discharge Indicator (BDI) and a diagnostic kit for these batteries, but I haven’t had time to find out if they are still available. My understanding of the User Guide however is that the BDI is required for a series connection.
I’m not sure what to do with these yet, and I don’t think I’d want to replace my group 31 AGM battery in the camper with these just yet. What about connecting them as a secondary battery bank on a four position battery switch ( Batt 1/Batt 2/ 1+2 / Off ). Due to their small size, I could make a place to stash them inside the camper without too much trouble. They could possibly be a good source of overnight power (especially in the winter) that I wouldn’t have to worry about running them down below 50%.
U1-12RT Data Sheet
Valence RT User Manual
  • I finally figured out the date code on these batteries after realizing there’s a printing error on the page of the User Guide that breaks down the serial number. The example serial number has too much space between the fields, so they don’t line up with the field descriptors.
    Both batteries have the same date codes (138) so I believe these batteries were both built in the 13th week of 2008.
  • NRALIFR wrote:
    Not sure what to tell you. That’s supposed to be a link to manualslib.com. It opens for me without the warning.
    It opens, but after a few pages I got the scary warning. Zia was scared too. :)
  • 2oldman wrote:
    DO NOT click this. I got a phony Windows corruption warning.
    Not sure what to tell you. That’s supposed to be a link to manualslib.com. It opens for me without the warning. Here’s the manual on another site, but I would have sworn that manualslib.com was the safer site to link.
    Valence RT User Guide
  • Yeah, just trying to get an idea of what kind of capacity they have with the two of them paralleled.
    I don’t have a DC amp meter that can handle more than 10 amps, but if I can trust the numbers from the Kill A Watt meter, I think I was putting about a 12 amp DC load on it. It ran for about 5.5 hours. The battery voltage must’ve gotten down to 10 volts (under load) because the BMS shut it off.
    This is before I unplugged the batteries from the inverter. (0.833 volts DC)
    As soon as I unplugged the batteries, the voltage jumped up to 11.22 volts. I guess the BMS is working :B
    I’ll cycle them a few times and see what their trend is.
  • It sounds like you are already running a capacity test, if they still have reasonable capacity (say > 35Ah per battery) then hook them up and use them. They are high quality batteries. There is no issue with running lithium batteries in parallel, and unless you have a 24V system, you wouldn't want to run them in series.
  • Looks like a few good youtube vids on them. I'd be sure to check on the parallel connecting. Not always recommended for Li's.
