path1's avatar
path1
Valve core that won't accept or expell air?
Lady up the way drives her MH about once a month for a short drive and then airs up her tires. Has been doing this for over 4 years now. She asked me to see if I could get air in one of her inside dual. Her set up has a valve stem on her 22.5 inch tire. Then a 4 inch valve extension. I couldn't get air in or out either. I took the valve extension off and the valve extension and it works right. I can get air going both ways, in and out.
But can't get air in or out of valve stem that is attached to rim.
I think most folks have messed with a leaking valve stem.
What about a valve stem that does just the opposite. No air in or out.
  • We'll never know what the real problem was. She took it to tire place, $39.00 for new valve stem.
  • Our Motorhome came with the screw on valve extensions. For the most part they work fine. A few years ago, I had a problem where one of the inner tires won't take air and if I tried to check the pressure the pressure would be 0. Like you, I took the extension off and blew air into it and it worked fine. Put it back on and it still did not work.
    Our valve extensions have a jam nut which increases or reduces the amount of thread on the extension on both ends. On the end that attaches to the valve stem, I tightened the jam nut about 2 complete revolutions and then they worked much better. I haven't had a problem since.
    It is possible there could be a problem with the valve core or the valve stem. I had a valve stem on a previous vehicle where the valve core would rattle loose. You can buy a valve core removal tool at any auto parts store for a buck or two. Remove the valve core and re-seat it.
    -Michael
  • Use the little straw thing and shoot some WD-40 or penetrating fluid into the valve and let it set for awhile. Might free it up if it is frozen.
  • If you can't DIY, goeth to a tire shop and replace the operating part of the valve. FWIW, I have a small core wrench that might fit between the tires or at the most, demount the outside wheel and have at it. BTW, I can count on one hand the number of broken core stems I've seen. Improbable but totally possible.
  • DrewE wrote:
    It's plausible that the valve stem could be plugged, I'd imagine particularly if there was something along the lines of fix-a-flat put in at some point.
    If it were my problem, I'd probably remove the wheel (so as to get access) and see if I couldn't get things working by removing and replacing the valve core. If the air won't come out when the valve core is removed, it's probably time to go to a tire shop, I'd guess. It may be possible to free up whatever is causing problems by poking at it with a wire or something, but that strikes me as potentially a pretty dangerous stunt to try.
    Thanks...I never thought about maybe tire has some fix a flat stuff put in it. I'll ask her.
    Thanks
  • DrewE's avatar
    DrewE
    Explorer III
