rtaylor0830's avatar
rtaylor0830
weber q adapter help
I have a weber q that works fine off of the trow away propane bottles but when i try to hook the adapter up to use the 20lb bottle it will not work. The grill does not even smell like the propane is in there when hooked to 20lb tank.
  • YamaDooed wrote:
    Check the hose end that replaces the disposable fitting. What happens is the pin on the Weber regulator is to short and doesn't depress the schader valve in hose enough to release the gas from the hose fitting.This happens on both the generic and weber hoses. I used a tire schrader valve tool and removed the valve completely to eliminate this issue. Unfortunate but Weber would not let me talk to engineering and only their bubbly customer service rep spewing responses from a trouble shooting flow chart about opening the valve slowly and sequence blah blah stuff was as far as they would go.
    That's a common problem & usually misdiagnosed as evidenced by the other responses. Also, the Acme fitting on the hose may not depress the tank valve enough. I have had tanks that I have installed a Retro Q Cylinder Valve Adapter which solved that problem.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    Marsland wrote:
    I've heard that you need to use a filter when using the bulk tank. Any truth to that?
    I've never heard that. Didn't know they made such filters.
  • I've heard that you need to use a filter when using the bulk tank. Any truth to that?
  • Check the hose end that replaces the disposable fitting. What happens is the pin on the Weber regulator is to short and doesn't depress the schader valve in hose enough to release the gas from the hose fitting.This happens on both the generic and weber hoses. I used a tire schrader valve tool and removed the valve completely to eliminate this issue. Unfortunate but Weber would not let me talk to engineering and only their bubbly customer service rep spewing responses from a trouble shooting flow chart about opening the valve slowly and sequence blah blah stuff was as far as they would go.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    X3, like everybody else said, the problem is with the hose/tank/etc, not the Q.
    All modern tanks have that internal afety valve that can restrict flow.
    Check this link to troubleshoot:
    Low BBQ flame problems
  • dan-nickie wrote:
    Sometimes you have to turn on the 20lb bottle slowly so that the leak detector does not kick in and stop the propane flow.
    BINGO!
    If you turn the valve on any other way than VEERRRRYY SLOOWWLLY, the flow limiter kicks in and shuts the flow down to next to nothing.
    The Weber valve needs to be off, then turn the tank valve VERY SLOWLY. Then I turn the Weber valve to low. Light it, let the flow stabilize, then turn it up. Some tanks are worse than others. If it kicks in, you need to take the hose off the tank with the Weber valve open to bleed it off, let the tank set 5-10 minutes and start over. My propane fireplace does it too.
  • wtravlr1 wrote:
    I found that i had to use a Weber hose for some reason, kept thinking i was out of propane, turned out the hose I had was the culprit. I, of course replaced the regulator and burner first! Then found out it was just the hose. Start with the easy things!
    X2 used mine several times with an aftermarket hose. Sometimes good, sometimes not so good. All problems went away after using Weber hose.
  • I found that i had to use a Weber hose for some reason, kept thinking i was out of propane, turned out the hose I had was the culprit. I, of course replaced the regulator and burner first! Then found out it was just the hose. Start with the easy things!
  • Sometimes you have to turn on the 20lb bottle slowly so that the leak detector does not kick in and stop the propane flow.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
