- HuntindogExplorer
mena661 wrote:
Actually we don't have a winner as newer converters don't need a battery at all. This is not conjecture, this is fact. The OP said he only does full hookups so it would be best if he posted make and model of converter. That would tell us if he needs the battery or not. Personally, I'd get a battery regardless just in case the park loses power. That will at least let you run the furnace for a night.
I didn't mention the converter.
I suppose on a TC one could set it up to draw off of the truck battery...Sort of unconventional, and I wouldn't do it. I like the battery isolated so that the truck will always start.:B - bikendanExploreri just surprised that someone with a truck camper, never dry camps or boondocks.
i thought that was the beauty of having a TC. - MEXICOWANDERERExplorerConvert it totally to a "Park Model". No 12 volts at all. Nothing.
- mkirschNomad II
realter wrote:
I am referring to my truck camper or sometimes called a slide in. Any harm in using it with a dead battery, if I only camp at places with electrical hook ups?
Yes.
The converter will overheat trying to charge the unchargeable dead battery.
The dead battery will also kill your truck's battery, leaving you stranded.
Remove the dead battery from the camper. - 69_AvionExplorerI would have an on board battery even if I had a modern converter. I can't imagine only using my camper in a campground with power, but I'm sure there are folks that like it that way. My camper is older and I have a small battery charger, with no modern converter. As stated above, how would you run a modern refrigerator while on the road with no 12 volts? My original refrigerator and water heater didn't require 12 volt power, but when I rebuilt the camper I put in modern electronic ignition. I don't regret that at all. It is much nicer.
So to answer the OPs question, if set up properly you can run a TC without a battery, but with modern appliances you can't use them on the road without the 12 volts. - SimplygibExplorerThe 12v for your circuit boards, detectors, lights, water pump, etc. can come from the converter or a battery - so technically a battery is not required (at least on rigs with converters that don't require a battery to be hooked up). But what if there's a power outage at the campground? No fridge, no detectors, no lights, no water pump, no furnace fan ..... And what about when you're driving? What powers your fridge circuit board if you have no battery? I don't think the 12v coming through the 7-pin connector will power those things, at least not on all rigs (for my old camper, it only powers the camper's running lights).
- You can get by fine with no battery in a truck camper if that is the goal.
The 12 volt items will be temporarily not functioning unless they have power including furnace, fridge, propane water heater, lights, water pump, fans etc. 12v power can come from the truck or the converter when plugged in.
An old unit with an old converter such as magnetek 6300 needs a battery to filter ripple in the poor 12 volt supply.
You might have the moderator move this to the truck camper forum to get more specific experience. - mena661ExplorerActually we don't have a winner as newer converters don't need a battery at all. This is not conjecture, this is fact. The OP said he only does full hookups so it would be best if he posted make and model of converter. That would tell us if he needs the battery or not. Personally, I'd get a battery regardless just in case the park loses power. That will at least let you run the furnace for a night.
- HuntindogExplorer
wa8yxm wrote:
Francesca Knowles wrote:
Not that it matters in this case, since we're talking about a camper.
The law varies from state to state, I know of at least one state where any TRAILER over say 1500 pounds needs aux brakes,, Camper may mean trailer or slide in pick up camper.
On a pick up camper.. If you have a fridge, Air conditioner or other device that uses 12 volt for control.. and for one reason or another you "Drop" the "house" part and drive off in the truck... You need a battery to power the fridge's control (less you have shore power) to power the furnace (less you have shore power) to power the lights (Less you have shore power ) and you don't always have shore power.
We have a winner!!
Most if not all newer TTs,TCs,MHs, etc. need a constant 12 volt power supply to maintain voltage for various items. Fridge circuit board, propane/CO detectors, and of course if a TT the brakes. - wa8yxmExplorer III
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
