J_R_in_Missouri's avatar
Jan 01, 2020
Where is #2 Black tank pull valve Crusader ?
Have control board with a #1 and #2 black tank rocker switch. 1st tank shows empty 2nd shows full. Trying to located pull valve. This is a new to me 2019 Crusader by Forrest River. I am fulltimer in Texas. All help I can get to avoid a bad problem! Thank You !
  • After a complete inspection of the underbelly, driver’s side of your Crusader you can’t fine the pull valve?
  • I am going to take a stab at this as my Wildcat is built nearly identical to the Crusader, in fact I think in the same building if I'm not mistaken.
    Anyway, my black and bath gray tank valve handles are outside underneath and next to each other while the valve for the galley is a few feet further back by itself near the tires. Did you get down and take a good look underneath in both directions?
    Dan
  • What MODEL do you have?
    2 waste tanks (1 grey/1 black)....handles for dumping should be in the 'universal docking center'
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
