DrAnthony
Jan 10, 2018Explorer
Thank you so much for your detailed response. This is exactly what I was trying to figure out :D
I can get the 510 for $340cad, and the 320 is $320cad. For the $20 difference, would you go with the 510?
Old-Biscuit wrote:
Dometic 320
*Right side foot pedal (easy snap in/out water valve)
*1 pint water usage per flush.....rim flush
*toilet bowl seal....easy R/R
*Bowl/base factory sealed
Less parts/easy seal & water valve replacement
But if bowl/base factory seal leaks.....replace complete toilet
Slightly Larger Toilet
22" Depth
19 3/4" Height
14 3/4" Width
Dometic (Sealand) 510
*Left side foot pedal (remove side cover to access water valve--then remove screws to pull water valve)
*<1 pint water usage per flush....standard flush from rear of bowl
*toilet bowl seal.....separate bowl/base to access seal. Adjustment band used to hold the two parts together
More parts/must disassemble to R/R parts
But parts can be replaced vs tossing whole toilet
Slightly smaller...still a full side toiet
20 1/2" Depth
18 3/4" Height
15 1/4" Width
