yankee camper wrote:
Well then I guess my antenna has been malfunctioning for the last six years because the crank handle did not and should not be turning when moving the directional handle. Do you really think that the system is designed so that the antenna lowers when you change the direction is being pointed? Maybe yours is not working right and you don't know any better because it's always been like that for you,however that doesn't mean it's working right.
Um- if the elevating handle doesn't turn with the directional handle, you are raising or lower it, as you would be rotating the housing and lift gear around the worm gear- it's just that it takes a LOT of turns to raise and lower, but you can only rotate once.
Either way, it's really of little or no consequence.
