Skip___Jackie_T's avatar
Dec 13, 2013
Winter Storage for Battery
Storing my TT for the winter, should I leave it plugged into shore power to keep the battery charged with the converter or should I disconnect the battery and connect my Battery Minder to keep it charged?
Thanks for your advise. Skip
  • NHIrish wrote:
    Your battery tender may be better than most converters.
    But we will not know unless the OP tells us what converter.
  • As hershey said, a good fully charged battery will retain it's charge in cold weather. It's actually hot weather that drains a battery but they're capable of putting out more current in warm temps vs cold. Charge and leave it disconnected or put a battery minder on it.
  • Mine stays plugged in 24/7 when home. No special charger, just the factory one. Battery still good on my '05 5er, just add a little water every spring.
  • I still have my 2006 battery running strong with a small line hooked up to solar on the roof. Never had to touch it all these years but I do think I will replace it soon just out of age and to be safe.
  • I have no idea because I have no idea what converter you have. There are lots of brands and lots of models, tell us what you've got.
  • I would remove it and use the trickle charger. Cheap operation and will be more than adequate to keep it charged.
    Actually, a good battery, fully charged will keep its charge for months at a time with little loss of amperage. My '57 Ford keeps it charge for 6 months at a time between starting. My golf cart (gas) battery keeps it charge for 8 months between use every year without the use of a charger.
