speedy72vega's avatar
speedy72vega
16' Keystone Passport cold weather camping Q
Hi all, new member and new RV'er here. My wife and I recently purchased a Keystone Passport Ulrta Light that is an extended season trailer. My question is this: I am planning on going camping over the New Years weekend in NW Oregon. The average temps at that time of year seem to be around 40f in the day, dropping to mid-high 20's at night. From what I have read here, I will be adding anti freeze to gray and black holding tanks and run off of my fresh water tank. The thing that I am concerned about is the fresh water tank drain. It's a small hose, probably 3/8" ID hose with a plastic cap on the bottom, it sticks down about 4 or 5" below the bottom of the trailer. I am worried about the water freezing in that hose and breaking it, I would appreciate some feedback from the seasoned RV'ers here, thanks.
  • speedy72vega wrote:
    Any thoughts on the fresh water drain tube? Should I put some kind of insulation over it just in case?
    My trailer also has a drain tube for the fresh water, maybe sticks out 3" from the belly. the valve for the drain is inside the cabin of the trailer, so its just an empty tube sticking "outside" - nothing to freeze as long as the heat's on inside.
    where is the valve for your drain, is it inside or outside your trailer?
  • Thanks for the replies, good to know about the anti freeze. We are going to be staying at a campsite that has full hookups, so as long as there are no problems at the campground, power shouldn't be an issue. I can carry 40 lbs of propane in 2 tanks, hopefully that will be enough.
  • No need to waste your money on antifreeze in the holding tanks. Biggest worry is going to be propane. Be sure the gas tanks are full, you have lots of blankets, warm clothes, and lots of power. Youll need them all.
    If you mean RV AF, no, it doesn't work too well when diluted. For those temps you can safely keep water in your holding tanks.
