Grit dog wrote:
FishOnOne wrote:
For me the 20" tires look too big on the ram. The proportions just ain't right, but the 18" look much better. As for load carrying capacity IIRC the 20" is a tad bit higher along with the price tag when replacing them.
But do dubs look good on a super duty to you?
I don't know what "dubs" are.... But perhaps I'm not as hip as you.- BedlamModeratorMy OEM Ford 18" rims and tires were fine for my 4000 lb truck camper. Adding the tongue weight of my enclosed trailer was when I had to be anal on how I loaded the camper and trailer to stay under the wheel ratings. Once I went to 19.5's, I didn't worry about 8000 lbs on the rear axle.
- JIMNLINExplorer III
Cabman 850 wrote:
Looking at new trucks and notice that several new trucks are coming with 18 or 20" tires. I will be hauling a 4000 lb TC. Any preferences on size and why? Thanks in advance!
You may want the mod or adm tp move you over to our truck camper forum for better input from members who have the same truck and a 4k-5k truck camper.
If they don't then check out the tc forum. Many choose to go with aftermarket 19.5" wheels and tires for 4xxx load capacities. - Grit_dogNavigator IIIMe again is right in that with 4klbs you'll be right at the published tire and rim ratings, likely over a bit. Depends where CoG of the camper is, but presuming you're looking at long beds if you're looking at air suspension.
Long bed may put just enough weight forward to stay under those limits.
Either way, long or short bed, the truck is easily up to the task. I'm over 4klbs on a 10 year old short bed version of what you're looking at and its been cross country and to Alaska and back. Last 5000mi trip was actually on new ram OE 20" tires and wheels. No problem. - Grit_dogNavigator III
But do dubs look good on a super duty to you? - Me_AgainExplorer IIIA 4000 pound truck camper is most likely going to over load a SRW 3500. You need a dually or put 19.5 rims and tires on it! However you will still be over the placard RGAWR. Chris
- Old-BiscuitExplorer IIICheck the door jamb for the 'Tire and Load Information' sticker.....what is the payload (cargo carrying capacity) of that SRW???
- For me the 20" tires look too big on the ram. The proportions just ain't right, but the 18" look much better. As for load carrying capacity IIRC the 20" is a tad bit higher along with the price tag when replacing them.
- Cabman_850ExplorerThank you all for the replies, good stuff.
- jus2shyExplorer
Cabman 850 wrote:
3500
OK, in the case of the 3500, they use fewer leaves (I think it's only 1) to locate the axle, along with 2 or so "Half-leafs" that prevent axle wrapping. Then the air bags over the axle provide the primary support for a heavy load. So when you are unloaded, the airbags run a lower pressure and should give a softer ride. When laden, the airbags receive more pressure and return to the stock riding height.
I'm sure the airbags will be a maintenance item, but they tend to last a pretty long time.
Found a link to a trailer life forum where a member shows his 3500 air suspension setup: Trailer Life Link Of course it's this website with a different url on it, but this came up on google first and I was too lazy to find it here.
44,056 PostsLatest Activity: May 04, 2014
