- rsaylor3Explorerhttp://nissannews.com/en-US/nissan/usa/presskits/us-2016-nissan-titan-xd-press-kit
I think there may be a good place for this truck. We still have to wait a bit and see further reviews and tests to make sure though.
We should ask be happy anytime a manufacturer makes changes and pushes the envelopes. It's what brings us better products from all of the time and time again. Wishin wrote:
I'm mostly skeptical of this truck with regards to payload. It weighs an awful lot but I haven't yet seen a GVWR number so I really question if a loaded up model with top 2000 lbs of payload or come anywhere's close.
GVRW is 8800-8990 pounds, curb weight 6709-7480. An S trim 4x4 model has an almost 2100 pound payload, while a Platinum trim 4x4 is just under 1500. Not 2500 series territory, but well above the only other truck in its class which has payloads in the 900-1500 lb range.
The S model 4x4 with an approximately 9K GVWR and 7K curb weight is very close to 2500 series diesel pickups of 15 years ago. Power specs are about there as well.
So, all rhetoric aside this truck does appear to fit right in between most 1500 series and 2500 series pickups in terms of payload, GVWR and towing capacity. The exception is the F150 with the max payload/max towing packages, which roughly equal or exceed the Nissan XD specs.- Mike_UpExplorer
thomasmnile wrote:
Saw these specs in a Detroit Free Press review of the XD published this week:
Specifications as tested
Engine: 5.0L 32-valve V8 diesel
Power: 310 hp @ 3,200 r.p.m.; 555 lb-ft of torque @ 1,600 r.p.m.
Transmission: Six-speed automatic
Wheelbase: 151.6 inches
Length: 242.9 inches
Width: 79.4 inches
Height: 78.7 inches
Curb Weight: 7,480 lbs.
Is that curb weight correct? If not mistaken it weighs more than my Ram 3500 SRW with the 5.9 under the hood.
The review stated Nissan claims a towing capacity of at least 12000 lbs. but no mention of payload capacity. Definitely need some wallet capacity to buy it. The model tested (Platinum Reserve 4x4) had a sticker of 60K.
Yes, the Titan with the Diesel engine weighs more than the F250 (same config) with a 6.2L Gas engine by 200 lbs. "YET" it has a GVWR that's 1000 lbs "LESS". This isn't a HD pickup, it's a very heavy 1/2 ton with 1/2 ton capabilities. - thomasmnileExplorerSaw these specs in a Detroit Free Press review of the XD published this week:
Width: 79.4 inches
Height: 78.7 inches
The review stated Nissan claims a towing capacity of at least 12000 lbs. but no mention of payload capacity. Definitely need some wallet capacity to buy it. The model tested (Platinum Reserve 4x4) had a sticker of 60K. - WishinExplorerI'm mostly skeptical of this truck with regards to payload. It weighs an awful lot but I haven't yet seen a GVWR number so I really question if a loaded up model with top 2000 lbs of payload or come anywhere's close. Personally this truck does not appeal to me, but I'd love to have this engine in my Suburban!
- otrfunExplorer II
spoon059 wrote:
And, that difference is exactly my point. Those who professed the Ecodiesel DOA (i.e., worthless) forgot or ignored the fact that not everyone has the same needs and wants. After more than a year of production, and scrutiny, the Ecodiesel is far from DOA.otrfun wrote:
I don't think its DOA, it just isn't what I hoped it would be. I ended up buying a Ram 2500 this summer because I needed the extra payload that my Tundra just didn't have. I think a lot of people were hoping that the Titan would offer a little better fuel mileage, a little better towing experience and a little better payload.
A year or so ago many on rv.net professed the Ecodiesel as DOA due to payload, weight, price, and various tow tests.
Deja vu?
I am sure there is a market for this vehicle, but its not as stout a vehicle as we had hoped.
There is a difference between a worthless vehicle and a vehicle that doesn't meet a specific need...
Fast forward to the Nissan XD Titan Cummins.
Deja vu? I lean toward yes. - spoon059Explorer III
Deja vu?
There is a difference between a worthless vehicle and a vehicle that doesn't meet a specific need... - hvacExplorerFor those who have not been on the 1500 eco diesel forum, go to the towing section and read some threads about what the 3D can do and in commercial applications. Its not perfect guys but they are proving the little Italian diesel in real time towing 6-10k lbs and receiving mileage figures that are well incredible. Some have over 190k miles and running perfect. It appears this power train with the ZF 8 speed and combining full air suspension will prove itself as a viable towing machine for us in the RV world.
Does it have emission issues? yes. Should you buy your diesel and DEF at truck stops? yes. The Nissan will have them as well. Heck the big rigs are dealing with the challenge of a cleaner exhaust. That being said, we do have options, and its not all a screaming gasser getting 10mpg. I welcome the innovation... - brulazExplorer
Deja vu?
Really depends upon your trailer's tongue weight and how much you like diesel.
For sure they both make for great boat haulers where people are often towing at 5-10% TW.
Personally, I like diesel's low rpm HP and torque, and mileage having cruised all over with a 2005 Passat TDI and 2500# tent trailer. But my current trailer has over 1200# TW, and we carry lots of stuff to Florida, so I need at least 2000# payload.
I didn't really think the EcoDiesel would work given the RAM 1500's typical low payloads. But Nissan was/is advertising that the XD is something more than a half-ton, so we assumed something like an F150 with HD Payload. Nope, payloads are nowhere near that. Thus the greater disappointment.
The only way it is different than a typical half-ton is that it's heavier, for better or worse, and has a 5L Cummins diesel. At least with the diesel it's mileage won't be as bad as it'll be with the 5.6L gas V8 they'll also be offering.
There are advantages to heavier trucks: stronger components, the Titan XD drive train is heftier than the F150 HD Payload truck to support all the low rpm diesel torque; the frame might be stronger as it comes from the NV 2500/3500 vans; a heavier truck can be pushed around less by a heavy trailer (but how heavy a TT can you pull with low payloads?); a heavier truck might be safer in a collision with an Elk (got this from another forum).
Anyway, I'm still waiting for the KingCab numbers. Maybe those will look better, and we're interested in shorter trucks anyway. - otrfunExplorer IIA year or so ago many on rv.net professed the Ecodiesel as DOA due to payload, weight, price, and various tow tests.
Deja vu?
44,070 PostsLatest Activity: Jul 15, 2026
