Mike_Up
Nov 13, 2015Explorer
brulaz wrote:
Sadly it looks like the payloads on the CCab 4x4 version of this truck will be around 1700#. Guess we'll be looking elsewhere for our next truck.
http://www.titanxdforum.com/forum/177-2016-titan-xd-news/8457-we-have-titan-xd-tow-ratings.html
Wow, the crew cab 4WD looks to be about 1590 lbs payload, same as my F150. Yet that truck is heavier than a F250 Crew Cab 4WD 6.2L Gasser, with over 1,000 lbs less GVWR.
Better off with a F150 Ecoboost since they both share turbos. The lighter 2011 - 2014 F150 has the exact same torque to weight ratio from the F150's significantly lower weight, but the Eco's max torque comes on a bit later with 2500 rpms.
With the Eco's higher 365 hp and 1630 lbs lower weight, you'll have a lot more working horses. Using the same horsepower to weight ratio that the new Titan XD has, would put a very low 242 hp into the lighter F150.
With the Titan XD horsepower to weight ratio and torque to weight ratio, that would equate to the same configured 2011 - 2014 F150 having 429 lbs of torque and 242 horsepower. The Ecoboost F150 has 365 hp and 420 lbs of torque.
Titan XD @ 7400 lbs UVW and 2011 - 2014 F150 Ecoboost @ 5770 lbs UVW.
Looks like another DUD. Had the 2004 Titan and was a POS. Had a 2005 Pathfinder, and not much better. Under performing garage queens.
