ncladfw3's avatar
ncladfw3
2019 coleman 264RL tire pressure?
The placard on the side is weathered and I can't read the psi. It's not in the manual either. Anyone know the correct psi for coleman 264RL? I read I shouldn't go by what is on the tire. Tires are currently at 40psi which seems low.
  • Take whatever it weighs (gvw if you don’t know actual) divide it by 4, look up the pressure for that weight on a chart.
    Or go max pressure for the tires on it assuming they’re the proper ones for the trailer, if you’re not willing to look it up.
  • Most RV trailers come with OEM tires that are just barely adequate to cover the axle ratings when inflated to sidewall pressure indicated.
    Unless someone replaced the originals, with a way over rated tire, use the likely 65 psi max. You should have stated the tire size, load rating, and tire max pressure, for best answers.
    Even a C-load range tire would be 50 psi, so yes 40 psi is likely low.
    Jerry
  • I would think that you have duel 3500 lb. axles on your trailer. That being said I would hope that you have at least 20575/15 C load range tires on the unit. I had that size tire when I purchased my Trail Blazer and Coachmen called for the tires to be inflated to 50 psi. My Trail Blazer had a GVWR of 7900 lbs. which is just a little more than your Coleman.
    I would try to find a tire mfg. pressure guide and go from there. It would alshelp to have the rig weighed in order to cut down on the confusion.
