Old-Biscuit
Sep 17, 2017Explorer III
Pin Box mounted Jumbo Level.....I can watch it via truck rear-view mirror when pulling in/backing in to site for Side-To-Side level.
Shows in 1" increments how much off level.
Set up blocking on low side based on what is showing on level (1", 2" etc) then back onto blocking
That takes care of Side-To-Side
After chocking wheels I unhitch and park truck.
Then run front landing gear UP/DOWN as needed to level front to rear
For front to rear I use a 2' hand held level on bottom edge of bedroom slide out....which is right above the front landing gear extend/retract button
When level F/R I lower front 1"......go run rear stabilizers down tight then raise front back up 1"
Done.......rig level S/S & F/R and solid except for a little bounce form tires/suspension.
Pin Box Jumbo Level & Bracket
