Djsrcy
May 09, 2018Explorer
7pin wiring problem. Please help!
I have a new to me travel trailer.  I am having a few issues with the wiring.  Let me list those and then I'll list what I have done so far.
1. When headlights are on, running lights are not.
2. When I hit the brakes, the running lights come on.
3. When I use right turn signal, running lights flash.
4. left tail light is out completely.
Here is what I have done.
1. I have confirmed the tv wiring is fine.
2. I cut the 3 grounds that were attached to the trailer near the front. I restripped, added new ring connectors, cleaned up the contact point on the trailer, and used a new screw.
3. Did the same for the grounds coming off of each tail light going to the frame.
4. I replaced both rear bulbs.
5. I pulled off the tail light housings and cut and redid the connections for those too.
6. I replaced the 7pin plug.
7. Opened the junction panel under the camper and everything LOOKS good.
I was and kind of still am convinced that this is a ground issue but have no idea what to check or how to check it. Been messing with this for days. At my witts end. ANY help is appreciated.
Thanks, Djsrcy
Thanks, Djsrcy
