- gmw_photosExplorer
pianotuna wrote:
....snip....
Oil filled heaters do not share that risk.....snip
.... At least one of our long term members "cheats" and puts a small fan on to blow on the oil filled units.....snip
When I am at home n the S&B in the winter, I use one of the oil filled rads in my kitchen, which is where I spend most of my time. I too cheat with a little fan. I found a small "personal fan" like you might use on your desk at work. About two and a half inches diameter. I set it on the floor aimed at the base of the oil filled rad, and some measuring with the non contact IR thermometer showed I was able to pretty much even out the heat of the radiator top to bottom, plus move a little bit of air. - pianotunaNomad IIIThe best thing to do is to "coat" the interior surface of the RV with warm air. One way to do that is to use radiant heaters--the type that glow cherry red. They heat the item they are pointed at--and that item re radiates warming the air. They are good at thawing out frozen water pipes.
The draw back to the medium wave infrared is that it can burn the item it is pointed at.
Oil filled heaters do not share that risk. However, they are slow in response and rely on convection currents to warm the interior of the RV. They are about the safest one can find. I like them best because I can turn one off when I cook electrically--and the heat from it will "coast" for a time. Then when I've finished cooking, I turn it back on. At least one of our long term members "cheats" and puts a small fan on to blow on the oil filled units.
Fan heaters warm the air but do not rely on convection. Hot spots are possible so do follow the directions carefully.
No matter what type of heater is being used--be careful!
I hope we are all staying warm in this latest cold snap. - trail-explorerExplorer II
Second Chance wrote:
...It would be much more difficult to get heavier wiring up to the roof than doing the modifications necessary in the lower utility areas of the trailer.
The heavy wiring is already up there, since it powers the A/C unit.
Should be 12 AWG / on a 20 amp circuit. - HuntindogExplorer
SoundGuy wrote:
Do you EVER agree with anyone?Huntindog wrote:
There are advantages to both approaches. BUt overall, long term the heat in the TT will be the same.
Incorrect. Warm air rises - a heater situated on the floor is generating heat where it's needed, warming the interior of the camper and occupants as it rises and is distributed about the camper. :B An A/C mounted heater is generating heat where it's not needed, at the ceiling, where it's trapped and there is no one to benefit from that warm air. :( The only rationale I see for an A/C mounted heat strip is for blowing warmed air into the bed ends of a hybrid trailer, otherwise it's a useless exercise in futility when a $20 floor situated electric heater will prove far more effective at distributing warmed air where it's needed.
Back to what I said, I will now explain in greater detail.
5K btu is 5K btu. This is a fact.
If you run a portable 5K heater in a TT for 24 hours straight and a 5K heat strip in a TT for the same amount of time... They will BOTH stabilize at the same temps. (identical TTs and conditions)
But most everyone won't run a portable unit 24 hours straight due to safety concerns. But a permanent install of heat strips is perfectly safe to leave running night and day, when you are sleeping or away. So if you are in a campground where the elec. is "free".. Then this is an advantage.
Don't obsess over the heat rising thing (I know it's hard but try) as that is what the fan is for. Blowing the warm air into the TT and mixing it with the cold air. - gmw_photosExplorerSpeaking of these little stand alone electric heaters, I've had various ones over the years that I've used for instance in my garage at home for a little added heat, and one thing I have noted about them is some have a pretty sensitive "thermostat", and others not so much.
If you want one that will maintain a fairly narrow temp range, you may have to try a few different ones, returning those that don't work the way you like.
EDIT: a couple of other things along this whole line of stand alone heaters. Two fun tools that can help you manage all this is a kill-a-watt meter to plug in and check current draw, and a non-contact IR thermometer to check for wiring/outlets/plugs getting warm. Probably not necessary tools, but fun and informative nonetheless. - pianotunaNomad III
clutch1 wrote:
You can buy a Lasco heater at Walmart for around $40.
Or you can buy a 1500 watt three heat settings heater from Walmart for $8.86 plus tax. They both provide the same number of btu's. - clutch1ExplorerYou can buy a Lasco heater at Walmart for around $40.
- pianotunaNomad IIIThe circulation of air from the roof top ducted units over comes any convection currents from warm air rising. The largest issue is they produce only 5118 btu's. Folks expect miracles from less heat that of a small burner on a propane stove.
I have my furnace on a different thermostat, so I can use all my various heating systems together giving me access to 23,000 btu's from electric and a further 25,000 from the furnace. - bobndotExplorer IIIMy 2 cents:
Maybe some floorplans work better than others, i don't know, just a thought.
After using RV's in sub zero weather, i found the entrance door to allow a lot of cold air into the TT. That always made the closest person to the door, feel cold no matter what the heat source was.
After hanging a H.D. drape over the door, I found a ceramic cube floor heater to perform better than heat strips on the ceiling .
The TT felt warmer but I will admit after many hours of NOT opening and closing the TT door, the heat strip seemed to level things out a bit when used to maintain warmth, but it takes a lot of time in cold weather.
The dealers I have personally known over the years shy away from heat strips. The one's i have spoken to like the cube or oil filled for efficiency.
Granted, most people are using their TT in much milder temps than I did but I would think the basics are still the same. Those doors leak air . Placing the cube nearer to that door worked best for me. But the heavier cold air is going to occupy the lowest points pushing the lighter warm air to the ceiling. You notice it when you step out of the shower, your legs feel cold and face feels warm . IMO, putting the warmer air low makes better sense to me.
gmw photos , i like your idea , a dedicated line. I have done that in the past in a make shift way. Your post here offers a more secure and safe line. I like....., tnx. :C - SoundGuyExplorer
Lynnmor wrote:
The fireplace, or any portable heater, is hot at one spot and cold a distance away.
With our current 19' couple's model the furnace brings interior temps up within minutes then switches off, allowing an electric heater sitting on the floor to maintain a comfortable interior temp. However, in our previous Spree which was much longer I found that running a fan or the A/C on fan mode (if we could stand the racket :() really helped distribute warm air throughout the trailer, avoiding cold spots in areas well away from the heat source.
44,067 PostsLatest Activity: Jun 01, 2026
