Jay_Pat's avatar
Jay_Pat
Adding higher, stop and turn signals on tt.
I ordered some LED stop and turn signal lights to mount up high on the rear of the travel trailer. Original plan was to run the wires along the outside surface of the travel trailer. I had planned to cover the wires with a wire cover track from one of the big box stores. I don’t like the thickness (too tall) of the covers. Re thinking this track idea.
So now, I’m starting consider running the wires behind the skin on the rear of the rv. I have pushed on the skin between the corners and the window. I’m not finding and horizontal supports in this area. I think I’m safe to snake the wires through this area. I've never done this before.
I would have to cut a hole large enough to guide the snake next to/along the backside of the skin (trying to stay out of the insulation). To cut a hole, I assume I would use a hole saw with a pilot drill adjusted close to the saw’s teeth ( keep pilot drill from drilling too deep). I’m thinking I need a hole large enough to guide the snake along the backside of the skin(not sure how to enlarge the hole as needed to guide the snake).
Now, my fears… Cutting an ugly hole and I can't get the wires snaked to where I need them.
I’m adding these lights so vehicles farther behind me can see what I’m doing.
Any thoughts? Thanks! Pat
  • path1 wrote:
    Don't know if this helps...on here somewhere somebody was posting about "wireless" lights some time ago.
    my preferences:
    1) greydenny hawks suggestion
    T1 leave well enough alone
    2) go with wireless
    3) surface mount some channel
    121) drill into rear, slam a snake around, create a leak.
    bumpy
  • I added some new lights about half way up the window. I was able to remove my old lights and run a tape measure up to make sure nothing was blocking the path for the new wires. It was an easy project to do.
  • Don't know if this helps...on here somewhere somebody was posting about "wireless" lights some time ago.
  • Also consider the window for access. You might for example be able to remove just the inside trim to get good access.
  • JayPat- I would not bother; your lights are pretty high up. I just did this on my toy hauler where the lights are bumper level. It was a pain but now I have lights at the top of the trailer.
    Yours are fins - following vehicles should be able to see your lights.
  • A fiberglass snake is about 1/8" diameter so a small hole will do the job. Remove the marker light to perhaps test the snake. Ditto for any thing inside in the general area. Going through insulation would not concern me.
  • RoyB's avatar
    RoyB
    Explorer III
    Its probably not a big deal but I would check with the DOT/DMV office first to see if what you want to do is approved for your local state...
    Hate to pay out for new lights and then have to remove them to pass your state inspection...
    I do know the lights must have a DOT approval numbers stamped on the lens... Another issue is your license plate holder requires a light on it above the License plate on the rear...
    Used to run into this all the time back in my OFF-ROAD JEEP Days...
    Roy Ken
  • I'm assuming, I can find a snake that will work.
    Pat
