Cvf0714ExplorerJul 31, 2016Adding new outletsWe are redoing the inside of the our 2005 Coleman bayside. We would like to add some more outlets. Any suggestions on doing so?
Mandalay_ParrExplorerJul 31, 2016My advice is to consult an electrician.Golden_HVACExplorerJul 31, 2016How many amps is the service to the RV?How many circuit breakers do you have inside?What do you plan to run?You might also consider buying and leaving inside a 25' extension cord, and a computer type power strip with 6-8 outlets, then power this from the campground GFI 20 amp line, so you will not be overloading the main service.Good luck,Fred.
Related ContentElectrical outlet issuesAdding a 12v outletAdded 12V USB outletsadding 12v outlet and switchAdding outlet for propane campfire
