Colo Native wrote:
Cummins12V98 wrote:
Colo Native wrote:
Cummins12V98 wrote:
The RV in your sig has about 12,350# GVWR with 20% pin weight you are at 2,470#. Does your truck sit level or is the rear lower than the front loaded?
The pin when weighed was 2360# it has about a 3" drop but it is level when not hooked up
I I understand you correctly your rear is 3" lower than the front with RV attached? If so potential buyers this is a perfect example of why you should opt for the 350 if choosing Ford.
That's not what this is about!
It is with him, if its not a Ram. Might ask him about the OEM air bags on the new Rams
As far as airbags Have had both Airlift, and firestone, no issues with either. I am sure Helwig are also a good option. I went with Airlift 5000 Ultimate this last time, had a $50.00 rebate . I think pick your brand, pay your money. I believe Airlift does have a little better warranty then Firestone.
