CptnBG
Feb 10, 2015Explorer
Alignment Question
Assuming the TC will be on the truck about 50% of the time would you get the alignment checked with or without the camper loaded?
egarant wrote:Buzzcut1 wrote:
I seriously doubt that any regular tire shop has a tall enoug bay to put my truck and tc on the alignment rack.
X2
Any alignment shop telling you otherwise only want to get more money from you..
ticki2 wrote:I agree. Do not get me started on the value of airbags. Simply stated, they can correct this. With all due respect, this subject as it pertains to Airbags goes way over most folks heads. Fact is, in my opinion, the adjustability of airbags can provide more than a fixed spring upgrade setup. It is difficult to discuss/argue due to most peoples beliefs in one liner solutions.
... I agree that 200#+or- on an average 4000# front end isn't going to affect the alignment that much , mostly the camber but that is only one factor . The rear end being high , low or level in relation to the front end will affect the caster angle which in turn affects the steering stability at speed .
Reddog1 wrote:
For me, I decided 200 pounds is just not much weight, so I ignore it and align without the TC. If I were concerned, I would have the front aligned without the TC. I would put a basket in the front, and load it with 200 pounds of sand, and have them put it back on the machine to see if there was any change. Obviously, you would have to weigh your front and rear axles.
